Spark Plug Wires ---- hmmmmmmm tin coated copper? PICS
Andy - Hammond,
07-10-2001 15:06:37
I went down to get a set of true copper core spark plug wires for my 8N (to replace the 2 slashed wires that had a entanglement with the nearby fanbelt) (grin) --- This is what the local NAPA place sold me --- tin coated copper wire --
check out pics and let me know if I should get something else or is this adequate - at $17.50 for the 4 - it seems kinda pricey.
Let me know what ya'll think...
third party image
third party image
Thanks,
Andy
Dell (WA)
07-10-2001 21:42:52
 Re: Spark Plug Wires ---- hmmmmmmm tin coated copper? PICS in reply to Andy - Hammond, LA , 07-10-2001 15:06:37
Andy..... the "tin" is on the copper wire so you can "solder" the wire to the brass end clips that fit down inna the distributor cap holes. Use only "radio" rosin core solder. Use any type alcohol to clean off the melted rosin flux after soldering. DO NOT USE ACID CORE SOLDER, its for radiator and copper pipe repair..... ..Dell
ANDY - HAMMOND, LA ------- THANKS DELL!!! 1 MORE ?
07-10-2001 22:26:37
 Re: Re: Spark Plug Wires ---- hmmmmmmm tin coated copper? PICS in reply to Dell (WA), 07-10-2001 21:42:52
Can you help me udnerstand why the plugs would be so rusted & the electrodes coated with the dark black carbon buildup. My 8n is always kept under a shelter out of the elements. (however the air is quite humid) (grin) ---
Should I adjust the fuel ratio due to the fouling or how do the plugs look? See other post below for the pic of the plugs.
Thanks
Andy
Dell (WA)
07-10-2001 22:37:19
 Re: Re: Re: Spark Plug Wires ---- hmmmmmmm tin coated copper? PICS in reply to ANDY - HAMMOND, LA ------- THANKS DELL!!! 1 MORE ?, 07-10-2001 22:26:37
Andy..... .yeah, your plug was a little black, but I didn't think too much about it. Because, I guessed you might have been jiggering around with your carb needles to try and get your power back. (that you un-knowingly were loosing thru bad sparkies) Get your sparkies undercontrol, and then work your tractor and then look at your plugs for color. As long as they're not carboned deposited or oily sooty, you're probably just a little rich right now.
I always use Permatex hightemp "Anti-seize" on my sparkplugs. (kinda silvery looky pucky). Torque plugs in castiron head 22-25 ft/lbs. Rust on the sparkplug shell doesn't hurt 'em as long as the white insulators are kept dry and clean..... Dell
JeffCT
07-10-2001 17:59:02
Hmmm, You sure you bought sparkplug wires Andy? That silver thing on the box looks like a BNC connector to me.... ;>) They probably "tinned" them to make them structurally stronger than copper alone.
smokie
07-10-2001 18:02:35
 Re: Re: Spark Plug Wires ---- hmmmmmmm tin coated copper? PICS in reply to Kevin CO, 07-10-2001 15:42:00
don also has oe type cloth raped collor coded .
didnt even ask the price already had so much in the rebuild i didnt think plug wires would kill me.
oh ya if it where me i would take those back napa dose sell the rite ones if thay have them in stocks single wire ruber coat.
gookluck
