Order Ford 8N Parts Online
8n front distrubitor timing
roger plante
07-11-2001 06:03:36
Having trouble timing to eng.Set points at 15 thousands points openning at 1/4 past bolt hole with straight edge. Seems like it is not advance enough.Driving me crazy any help anyone!!Thanks Roger Plante
Greg
07-11-2001 06:12:52
 Re: 8n front distrubitor timing in reply to roger plante, 07-11-2001 06:03:36
Roger,
If you want some more advance, put some more in. Loosen the adjustment screw on the left side of the dist. housing and move it up. Of course you made sure your centrifugal advance is working correctly. Right?
roger plante
07-11-2001 06:43:55
 Re: Re: 8n front distrubitor timing in reply to Greg, 07-11-2001 06:12:52
Have tried moving the side adjustment. I thought down was advancing? Do not know how to check centrefacle advance.Can't spell either Ha Ha Thanks Roger
