Lean Mixture?
9Njoe
07-12-2001 07:13:54
So I got this here 9N that seems to be running lean especially when idling. When idling it backfires and burbles a lot, doesnt stall but bogs when picking up a load. The idle mix screw had so be bottomed (full rich) to get it to start. Also, the backfiring got much better when I pulled out the choke part way. So I took off the manifold but it looked fine, gaskets OK, so I put some sealer around the intake ports and put the manifold back on.
After some more tinkerin, I decided that I would try to richen up the idle circuit so I got me an old idle jet for my TSX-33 and drilled it from the standard .025 to a whopping .040! Well now the tractor runs like a watch, The question is why? The ignition timing is right on, I dont think there are any intake leaks. The carb is tight and all the shaft packing is OK, Could it have something to do with the valve timing?
Does anyone know what the manifold vacuum should be at idle?
Any other suggestions would be appreciated.
Joe
Alan
07-13-2001 14:14:21
 Re: Lean Mixture? in reply to 9Njoe, 07-12-2001 07:13:54
I have rebuilt carbs and tried a new one with a lean mixture problem. I finally drilled it out with a #56 drill bit and it improved a lot. I plan to jump another drill size when I get a chance. I wonder if the rebuild kits are putting in the wrong size?? Maybe the gas is not so good either?? I don't pretend to be a mechanic but have taken it to some and they don't seem to fix it either.
