2n dead
overlandwagontim
07-15-2001 05:31:08
i put my 2n up last fall drained tank oil in cyl charged batt now will not start checked coil no power sw 1 side 6v outher zip balestresister zip ran jumper batt to coil still no start any help? thakstim
Andy - Hammond, LA - GT IT FXD YT????
07-16-2001 05:48:00
 Re: 2n dead in reply to overlandwagontim, 07-15-2001 05:31:08
This ain't Wheel of Fortune, you don't have to buy the vowels!
Oil zip, wire 2 sw1 on br in rd on td - mt on sd of tp br gt it fxd yt? myb u cld ty 2 us cmplte wrds - thn w cld hlp u ot.
hahahaha
JeffCT - It could be...
07-16-2001 17:17:59
 Re: Re: 2n dead in reply to Andy - Hammond, LA - GT IT FXD YT????, 07-16-2001 05:48:00
that Navajo code that they used in the war??
I'm taking Mind-Reading 101 by mail, allow me to translate...bg
07-15-2001 13:08:47
"I put my 2N up last fall. I drained the fuel tank and put oil in the cylinders. I charged the battery, but it will not start. I checked the coil, but found no power. I had 6 volts to one side of the switch, none on the other. No power at the ballast resistor. I ran a jumper from the battery to the coil and it still won't start. Any suggestions as to what to check next? Thank you, in advance, Tim."
Tim,
If you have power to one side of the switch and none to the other, it would lead me to believe that the switch is bad. You need to start at the battery and check all connections. Make sure they are clean, tight and bright. Work your way to each component in line and test it. You might have fried your coil when you ran a jumper from the battery directly to it.
If the tractor cranks and you have no spark, you must check:
1. Keyswitch and wiring(don't know where the cutout fits in all this)
2. Ballast resistor
3. Coil and wiring
4. Points and condensor
5. Plugs and plug wires On a tractor that has been sitting for an extended period of time there is the problem of the carburetor being gunked up with gasoline residue(varnish) that can clog the orifices and jets. If you can get spark and still no start, remove and thoroughly clean the carb with solvent and compressed air.
sorry . . . Dell (WA)
07-15-2001 07:27:17
Tim..... .Other than the fact that you can't get your 2N started, I can't make much sense out of your "helpful hints". This site doesnot charge by how many words you use to describe your problem or what you have checked out. I flunked mindreading, just ask my ex-wife..... ...Dell
Tom 8N396936
07-15-2001 18:36:16
 Re: Re: 2n dead in reply to sorry . . . Dell (WA), 07-15-2001 07:27:17
Near as I can tell his wife is 6 months pregnant with twins????? Or he owns a 2N that is still 6 volt? ;>)
keep the faith
tom
Snowplow
07-15-2001 07:34:00
Dell sure is a mean old son of a bear.... don't let him get you down he can probably tell you just what's wrong, but I totally agree. I have no idea what all this means. I think I need a compass to understand it?
bj/8N/mt
07-15-2001 06:10:53
Since I assume English is not your first language and since your English is a lot better than my German? Let me suggest a longer post. Site doesn't charge by the word.
Couple of questions: is the tractor still six volt? What voltage do you show at the coil top post with the points open and with the points closed. Are points set at .15? Can I assume no fire at the plugs?
More information and somebody will surely have the answer.
Your mileage may vary
Claus
07-15-2001 14:16:53
 Re: Re: 2n dead in reply to bj/8N/mt, 07-15-2001 06:10:53
Ich kann ihn auch nicht verstehen. No puedo entender este hombre con su problema.
Auf Widersehen...
Happy Motoring
Claus
bj/8N/mt
07-15-2001 15:12:11
 Re: Re: Re: 2n dead in reply to Claus, 07-15-2001 14:16:53
spelling test at six o'clock MST
better hit the books
