Order Ford 9N Parts Online
9N brake and clutch rod removal and repair
O. Magness
07-15-2001 11:37:57
I am in the process of repairing a 9N ford. the brake and clutch rod is worn out on the clutch end of the rod. I am having trouble remov
ing the collar that holds the brake backing plate on the rod, so I can get the rod out to weld it up and turn it down to correct size. will I have to heat it to get it off? Is there a source for t
hese particular parts, either new or rebuilt?
Also how hot should I heat the rear wheel bearing lock ring to install the new one? Until it is red, or before it gets red?
N9joe
07-16-2001 07:45:58
 Re: 9N brake and clutch rod removal and repair in reply to O. Magness, 07-15-2001 11:37:57
I had the same problem, Didnt want to heat it so I took a little dremel tool with a cut off wheel in it and cut slots in the collar until I could chisel thhe slots and break it. I used a standard 3/4 inch set screw shaft collar from the hardware store to replace it when I was done.
Happy motoring,
Joe
llamas
07-16-2001 04:13:48
Look closely and I think you'll see that the collar for the brake/clutch shaft is pinned onto the shaft - could that be your difficulty?
If you're going to the trouble to rebuild the shaft end, don't overlook the replaceable bearing bushing that's pressed into the axle housing.
As to the bearing lock collar - I've put them on with the collar heated much less than red - if it's bright metal (like it should be), a deep blue is more than enough. Make sure you have a suitable tubular driver and hammer ready in hand when the collar is hot, drop it on, and One Good Wallop should seat it tight. Don't be afraid to wallop it, the collar locks on the inner race and you can't hurt the bearing if you do it right.
HTH
llater,
llamas
