I am trying to isolate and fix a relatively CONSTANT sputter/pop problems with my engine. Let me preface this. I have a complete 12V system. Wires are clean, bright and tight. Unit burns no oil, no smoke, 120s on compression on all 4, gas flow is unobstructed getting to carb - battery is new. New wires (copper core), plugs (437s), distributor, cap, points, rotor, coil. things that haven't been replaced: ignition switch, condensor, dont know if points are properly adjusted. (egads!) Question 1: Got exactly 4.5v with tractor not running - points closed. (insert stupid question here) How do you crank the engine manually without being able to push it (has hog attached and is in barn -I guess I can move it out if needed) ---- Question 2: Trying to isolate a CONSISTANT sputter/pop/stalling problem I am having. Seems to stop stalling when I put the clutch in (especially after hogging for sometime - problem seems worse with new 437s - seemed to run better on the 216s --- any logic to that????? ) Question 3: Have not cracked open the carb (I am fearing that this unit is one of the primal factors in this) - Is a carb rebuild (with new kit) a nightmare to perform? Explain. Question 4: I am not ruling out sitcky valves - but I am getting 120 across all 4 cylinders with a compression test. I have not pulled the exhaust manifold but I cannot detect any cracks or leakage. Should I be looking in this area? Thanks for any and all info. Andy
