Order Ford 8N Parts Online
8N hydraulics
Rick in Kansas
07-16-2001 07:51:52
Have had problems with the hydraulics lowering too quickly on this tractor. Yesterday, I switched the position control lever from vertical to horizontal and the lift would not raise at all. Is the safety relief valve the culprit, or will the hydraulics need a rebuild? The hydraulic fluid was recently replaced, and there is now no water in it. Thanks.
ZANE
07-16-2001 18:27:46
 Re: 8N hydraulics in reply to Rick in Kansas, 07-16-2001 07:51:52
When you lower the little mode lever it puts the lift in the draft mode. The draft mode if the first to go when wear and tear take it's toll on the lift linkage.
The lift dropping too quickly can be from a sticking control valve or the linkage internally needs to be repaired and re adjusted.
See the link below
