Thanks for the advice guys!
roperboy
07-16-2001 19:51:36
i am going to go with the .060 bearings. this board is the best. thanks again.
Thanks For The Info Gregg..Big Mike
07-17-2001 12:03:53
 Re: thanks for the advice guys! in reply to roperboy, 07-16-2001 19:51:36
Always nice to know these things when sourcing parts . All of the tractor places only list .040 under. Will have to get the auto parts house a try for these...thanks again
Big Mike
07-16-2001 21:54:44
Actually you end up with less bearing surface area as the crank gets smaller. Bearing speed is reduced as diameter is reduced this is good for a high reving engine (8000rpm plus) but not a factor in a low rpm engine such as tractor motor. The bearings are thicker but the surface area is what carrys the load and the smaller the journal the less area. All of this stuff is important when building an all out race engine but a N motor is a low compression ratio low rpm engine. I agree with the advice given earlier that a properly ground crank will be fine at .060 under. I would like to know the source or manafacturer of .060 under bearings as all I see are .040 under. I have a crank or two that need to go to .060 under to be able to use them..... ..... ...Big Mike
Greg
07-17-2001 05:34:12
 Re: Re: thanks for the advice guys! in reply to Big Mike, 07-16-2001 21:54:44
Hey Big Mike,
My .060" under's were Clevite 77, which I believe is a Dana product if memory serves. They were a little pricey. About $90 for mains and rods. Also, they are not aluminum coated like most. They are just bare copper alloy. Didn't bother me or the engine. Been working great.
just think of all that EXTRA bearing you've got
07-16-2001 20:21:13
That's a bigger bearing mass, should keep the crank crankin' smooth. 8O)
rasputen
