Carbon/Black smoke-exhaust
9N'er
07-21-2001 07:33:28
Does that mean the fuel mixture is too rich? and the plugs are showing some minor carbon build up too.
And, if I have it right, I adjust the idle screw and tighten it a bit? To reduce the fuel and provide a leaner mixture of less fuel?
Please correct me if I have got it wrong. Or, give me an "attaboy" if I'm on the right track. thanks.
In ignorance, 9N'er
James Blankenbeckler
07-21-2001 08:39:39
 Re: Carbon/Black smoke-exhaust in reply to 9N'er, 07-21-2001 07:33:28
I have a 2600 ford gas and it was blacking plugs and smoking I went to the ford place in lebbanon Va and the man that owns it said a carb re build wont help those old tractors were made for lead The plugs in my 2600 and little 8n now burn clean so try lead subsitue in the mixtue it worked for me
tlak
07-21-2001 08:17:36
Make sure your intake is clean, no mouse nests and that your choke is fully open. I dont think the idle mixture has that much effect. On old cars I usually adjusted that by ear to gain the most rpm then turned the idle back down to the proper rpm. I would more think hot enough spark or compression.
Kevin CO
07-21-2001 08:13:56
And yes, black smoke, black insulaters on the plugs means too rich. They should be a light tan.
Kevin CO
07-21-2001 08:10:14
9N'er,
If I read the manual right, the idle adjust screw meters the air admitted. By adjusting in, you reduce the air and thus richen the mixture. Opposite of what you want.
Now, if I hear Del and others correctly, to adjust the idle correctly you wait until warm and let it idle. Then you adjust it for max RPMs. If your plugs show dark after that adjust, I would lean out the main/power jet. (screw in)
I am in the middle of dialing mine in now too after a complete clean/rebuild.
