Order Ford 9N Parts Online
9N Governor
Ron
07-23-2001 15:35:32
Can somebody explain how the govenor works and what are the symptoms of one going bad?? Thanks
bg
07-23-2001 16:59:37
 Re: 9N Governor in reply to Ron, 07-23-2001 15:35:32
The governor's function is to maintain a constant engine speed.The governor has 4 flyballs that ride inside a star-like cage disk. The flyballs rest on a tapered race, and the disk is mounted on a shaft. As the rpm increase the flyballs are thrown centrifugally outward against the tapered race, causing the disk to slide on the shaft, where it contacts a linkage that goes to the throttle arm linkage. If the engine starts to slow down due to a load, the flyballs move inward, causing the sliding disk to pull back from the linkage, thereby asking the throttle for more gas so the rpm remains fairly constant. As the load on the engine decreases, the shaft will slide back, decreasing the throttle.
If a governor is malfunctioning, the tractor will not respond to changes in load.
It's easy enough to check. Put the tractor in 2nd gear, give it 1/3 throttle, hold the brakes on and gently ease out on the clutch. If the tractor dies right down with no effort to increase power, the governor may need adjustment or repair. To inspect, remove the two mounting bolts and oil line(if there is one) and carb linkages, and pull it out. Inspect the flyballs, housing, cage and race for wear. The flyballs most often have flat spots. The cage can have worn slots, the disk can have grooves worn in it. The bushings and shafts can be worn and sloppy.
excellent . . . Dell (WA)
07-23-2001 17:57:43
 Re: Re: 9N Governor in reply to bg, 07-23-2001 16:59:37
Ron..... .bg really "nailed it" and is right on. Governor repair kits are readily available $85..... ..Dell
don b
07-24-2001 06:50:42
 Re: Re: Re: 9N Governor in reply to excellent . . . Dell (WA), 07-23-2001 17:57:43
Thanks BG and Dell.However, most any part is available for the governor seperately.Most of them will not require the complete high priced kit.The .220-.230 measurement between the shims and washer is also fairly important for it to work properly.I guess I'm lucky to have the Ford governor jig to make it easy to overhaul. don
