Over-riding Clutch
Alex
07-24-2001 04:42:59
How do you remove the over-riding clutch? I need to replace the seals. I looked at the unit and only saw a grease fitting and a small screw. I removed both but saw no way to remove clutch. Why are my old eyes missing?
Thanks.
ricker2n
07-24-2001 05:13:54
 Re: Over-riding Clutch in reply to Alex, 07-24-2001 04:42:59
The grease fitting and screw should be opposite each other. With them both removed you need to drive out a shear pin. Once you get the shear pin out the ORC should come right off.
Alex
07-24-2001 05:43:03
 Re: Re: Over-riding Clutch in reply to ricker2n, 07-24-2001 05:13:54
Thanks. If I had read farther down the list I would have seen the answer already there.
Thanks again.
ED-Illinois
07-24-2001 06:03:23
 Re: Re: Re: Over-riding Clutch in reply to Alex, 07-24-2001 05:43:03
I just removed my ORC and took me a while to remember that the inner shaft may not be lined up with the holes in he outer shaft. You may have to rotate it a couple of times until all the holes line up. Then you can drive out the roll pin
