Head Gasket
RussMO
07-27-2001 16:44:39
Well I said the chances of another call was very probable. The 6 to 12 volt is fine, but can you believe after all the work to convert, the head gasket has blown between 1 and 2 cylender. I pulled the head and intend to take it to a machine shop. What type of head gasket should I use and does it require sealent? Thanks
RussMO
07-28-2001 17:05:15
 Re: Head Gasket in reply to RussMO, 07-27-2001 16:44:39
Thanks everybody....
Isaac Carpenter, Jr.
07-28-2001 12:50:09
I too am in the process of replacing a head gasket for early Ford 8N. Not quite sure as to kind of sealent to use, I purchased Copper-a- Gasket [the kind that is in a spray can ] can anyone advise to what to use? I had the head shaved down, hope this was not the wrong thing to do. By the way I think the gasket is either steel or aluminum with a sandwich of what appears to be paper in between. Isaac
bj/8N/mt
07-28-2001 07:42:56
The composition head gasket from Ford New Holland is my preference. Better ability to take up any small deviations in surfaces. Put the gasket down dry. If you have studs no need for any sealer. If you have bolts I would put a little puckey on the threads of any bolt that goes into water. Torque it per the F O 4 spec and you ought to be fine.
Your mileage may vary
smokie
07-27-2001 19:15:38
some use mitalic some use soft gaskets no selent on ither one i used a mitalic works fine and you can do what you wish with the head but most here advic against shavein the head or deckin the block if you can help it you see the clearance is so close that if you shave any off you rick pistons hittin the head ,
goodluck.
