Oil in radiator
Phil
07-31-2001 08:09:47
I was in the process of getting things ready to pull off the engine base to check or repair oil pump. When i drained coolant from radiator there was oil in the coolant. Any what should I look for ? Phil
noff
07-31-2001 09:48:59
 Re: Oil in radiator in reply to Phil, 07-31-2001 08:09:47
Being that oil pressure is higher then radiator pressure, oil in the cooling system would make me thing that there is a head gasket leak. There could be other problems but that would be the first place I would look.
Dave Smith
07-31-2001 16:12:23
 Re: Re: Oil in radiator in reply to noff, 07-31-2001 09:48:59
Sounds like a compression test is in order. Also check close for coolant in the oil. I do not believe there is any way oil under pressure can get into the water jacket other than compression from the cylinders via a leaking head gasket or worse a crack. Lets hope it is not a crack. Some one will correct me if I am wrong.
Dave <*)))><
Paul8n
07-31-2001 08:20:33
Need more info, was there coolant in the oil when you drained it? What was the original problem? How much oil in the coolant?
Phil
07-31-2001 08:31:24
 Re: Re: Oil in radiator in reply to Paul8n, 07-31-2001 08:20:33
The origional problem was loss of oil pressure.
There was about a cup of oil in coolant , I didn't notice coolant in oil , but will check closer when i get home. Thanks Phil
