Shaving head does solve problem...
RussMO
07-31-2001 15:35:30
Well it certainly worked for me. Maybe it was the machine shop that did an excellent job, or just luck, but it "WORKED. They shaved it in a manner to leave most of the material on the valve side. There was also a small crack they repaired, and all for $49.00.
I don't think it can be said that the bolts will pull a head down to the tolences required if the unit is warped. This one sucked antifreeze like a trogan before it was milled. They took off .008 in places and the way it was milled prevented the valves hitting the head.
The old 2N runs like a new one, and boy will I sleep tonight. Thanks everyone for the help.
RussMO
It solved my problem of too much hair! ;^)
08-01-2001 06:55:21
 Re: Shaving head does solve problem... in reply to RussMO, 07-31-2001 15:35:30
That is an interesting way to true up the surface without creating more troubles. Thanks for the info.
