2N TACH
Russ
08-05-2001 15:32:56
I know this question has been discussed again and again, but is there a way to connect a tach. or proofmeter on front mount 2N? If so, how?
Thanks
bg
08-05-2001 16:08:47
 Re: 2N TACH in reply to Russ, 08-05-2001 15:32:56
You could theoretically change out the governor housing and use a threaded housing, cable and proofmeter. You could mount the proofmeter using a piece of steel or aluminum to make a bracket. This may require modifying the governor linkage.
Jay
08-05-2001 15:43:44
Hi Russ, Check below on this page,Dell posted how to do it for T.J. under heading RPM's.Your friend,Jay
