Order Ford 8N Parts Online
Thanks for the help,Time to put 8n back together again.
Phil-Maine
08-06-2001 15:23:59
I have a question about the gaskets. Do you put anything on any of the gaskets ? For example the oil pan , valve covers ,manifold or head ?
I would appreciate your experience,
Phil
Dell (WA)
08-06-2001 18:51:30
 Re: Re: Thanks for the help,Time to put 8n back together again. in reply to Bet sez, 08-06-2001 18:02:18
My Boeing designers manual lists 7/16 NF Brass exhaust nuts at 27 ft/lbs. These are brass so you strip their threads first instead of breaking the manifold stud and then clean the stud threads and then replace them with new p/n 33816-S 7/16-20 5/8 hex brass nut. Note: standard 7/16 NF nuts are 11/16 hex and will not fit the N-Manifold..... ..Dell
