Bush hog wheel
RussMO
08-07-2001 14:07:37
Please forgive me for asking this somewhat meaningless question, but without the wheel the "old" bush hog is useless.
I inherited a old bush hog that needs a trailer wheel/tire with a 3/4" I.D X 4 1/4 width hub. The old tire fell apart today. I only replacement wheels around here are the KingCutter wheels, which will not fit. Is this a standard size or is it possible to press another tire on the existing rim?
Thanks
burk
08-08-2001 05:21:32
 Re: Bush hog wheel in reply to RussMO, 08-07-2001 14:07:37
Check with Agri-Supply.com
I stumbled on their website the other day. I noticed that they have replacement wheels, hubs, bearings etc. Prices seem to be pretty good too.
I've never bought from them so that's all I know.
Brett - (MO)
08-07-2001 19:15:09
Russ, If you are anywhere near KC there is a place called Tractor Shed Inc. in Farley, MO that could probably get you the wheel you need. Email me and I can give you their number.
HTH
Brett
Farmer(Ga)
08-07-2001 18:11:22
Russ just type bush hog in search and their site will come up and click on dealer location. i just came from there. good luck Farmer(Ga)
Bob (WI)
08-07-2001 14:25:37
I'm probably way off base here but the tires on forklifts are pressed on, I have seen trucks around that do tire pressing, so you might want to check with a fork lift dealer or industrial supply they might be able to help you out but it's going to be pricey I'm sure.Just a thought
Sal
08-07-2001 15:31:44
 Re: Re: Bush hog wheel in reply to Bob (WI), 08-07-2001 14:25:37
Here, our NH dealer carries the Bush Hog brand and they have the solid rubber replacement tires on hand...Try looking for a Bush Hog dealer in your area, there seem to be a lot of them around.
Good luck
Sal
