Order Ford 8N Parts Online
Hyd. gasket/cover and others on 8N
PGL
08-08-2001 06:49:52
We tried to remove hyd. cover by removing pto shaft and then bolts on cover. We wanted to replace gasket. It would only come down 1/4 to 1/2 inch and "seemed" to be attached or stuck. Any ideas.
We had our 8N running pretty well. Water came out of overflow and hit engine. It stopped but won't start. We have tried to dry coil and front mount dist. Any ideas? Also, should we have overflow tube that hangs down below engine as we have pull type fan?
Carb. still seems to want to flood when sitting. Would changing float and float seat do any good? We rebuilt carb. awhile back but has old float (it seems to be good).
Thanks for all of your help.
rasputen
08-08-2001 07:34:33
 Re: Hyd. gasket/cover and others on 8N in reply to PGL, 08-08-2001 06:49:52
If it's really an 8N just slide the pump back and it will drop out. The control fork/T-valve is on 9N/2N.
bd
oophs-I forgot you didn't remove the Top cover-TimK is right!
08-08-2001 07:37:09
 Re: Re: Hyd. gasket/cover and others on 8N in reply to rasputen, 08-08-2001 07:34:33
Forgot, you still have the Top cover on.
TimK
08-08-2001 07:14:49
On the lift cover, whoa ! You have to remove the control arm from the pump which is connected to the lift cover before the cover can be removed. Get yourself an FO-4 repair manual, you will need it. My $.02.
PGL
08-08-2001 11:18:22
 Re: Re: Hyd. gasket/cover and others on 8N in reply to TimK, 08-08-2001 07:14:49
We have a manual but it does not show this well.
TimK
08-08-2001 13:21:52
 Re: Re: Re: Hyd. gasket/cover and others on 8N in reply to PGL, 08-08-2001 11:18:22
Check out your manual. It should be the I/T shop service manual FO-4 for 2n,9n,8n Fords. They are available for about $25 bucks which is a bargain from sponsors on this Board.
