Choke for 15 seconds! WOW!?!?!?!? Gasoline running out of the carb? A Niagra Falls! My 2N starts on the 2nd or 3rd piston up after choking for the first 1 or 2. I almost cannot get off the choke fast enough. (It rarely gets below freezing here.) You need an I&T FO-4 manual for your 8N. Klikkon the "Tractor Manuals" in the upper left corner of this page and spend the best $$ you've spent so far on your toy. Ref: I&T FO-4, p. 58, fig. FO86, view of inside of distributor with cap off: The "adjustment screw" (the one on the right) is used to adjust point gap to 0.015" after loosening the hold-down screw. i.e. There is no external point gap adjustment. Check the voltage at the coil with the points closed. It should be battery voltage (measure post to post - not on the cable connectors) minus 0.1-0.2 volts. Iffit ain't, clean ALL electrical connections between the battery and the coil. Those cheap, cheezy ignition switches give a lot of trouble attributed to many other things. wiggle the key in all directions, turn it off/on while measuring coil voltage. Any intermittent or variation from full battery voltage - replace the switch. Don't choke 'er to death. Elvy
