Box Blade
Paul8n
08-08-2001 10:28:44
Just went and picked up my new 6' box blade from farm and fleet. 550 lbs. of steel. Can't wait to put her on that 8n and have some fun. Between that and that front end loader I should be digging and a grading for awhile. Hope that box works better then a blade, cause that blade just wasn't cutting it. Update all after I get to play with it. Paul
Bill Oakes
08-08-2001 13:40:16
 Re: Box Blade in reply to Paul8n, 08-08-2001 10:28:44
Hi Paul,
If you are digging or moving dirt or gravel, you will find a box blade a big improvement. I don't think that you will ever wish it was bigger on the back of the 8N; 6 ft will make that little Ford earn it's keep. If you find yourself often with more in the box than you can easily handle, try using the draft control, as opposed to the position control. You will have better control of the load. This is really the way a box blade should be run most of the time. Have a good time, Bill
smokie
08-08-2001 13:18:05
i hope the 6 footer isnt to big i pull a 5 footer it is much better than a blade but i dont have fluid filled tires so with tthe 5 footer filled with dert shes pullen pertty good 6 footer may be a bit much if ya fill it up.
goodluck.
Jon D
08-08-2001 19:23:33
 Re: Re: Box Blade in reply to smokie, 08-08-2001 13:18:05
I agree with Smokie...I got a 5' for my 8N and it does a good job. I was afraid a 6' would be a litte much, but I too don't have fluid or weights in the back. Anyway, you'll have a lot more fun with this than the blade!
