Order Ford 8N Parts Online
8N\Furgason
Norman
08-09-2001 05:44:09
I took a job of restoreing an 8N for a guy. A buddy of mine looked at it and said it had a Furgason rear end and transmission on it. The casting does have a HF on it. Is this good? Does it hurt the value? Or is it a no no? The guy wants it completely restored to the last bolt and nut. Any input from you all will be appreciated. Later
Norman
Norman
08-10-2001 11:25:42
 Re: 8N\Furgason in reply to Norman, 08-09-2001 05:44:09
Thanks Guys, The man decided to make a work tractor out of it. Later
Norman
Big Mike
08-09-2001 11:16:20
We bought a parts tractor that was an 8N motor and transmission bolted to a TO-20 rearend. It was a running tractor that someone put together and used. The brake pedals are round on a T0-20 as opposed to the rectanguler ones on the 8N. Best fiqure out what you have to start with as a pieced together one is ok for a working tractor but if the guy wants a restored show tractor it best be all 8N parts or all T0-20 parts..... ..... ..Big Mike
Ed-Illinois
08-09-2001 06:09:47
Well, it would be hard to restore an 8N if it doesn't have an 8N rear-end, now wouldn't it.
Are you sure it is an 8N? Maybe it is a TO20, which looked very similar to the 8n, as well as having interchangable parts, as you can see.
If the radiator cap comes through the hood, probably an 8N. If it doesn't, you might have a TO or TE 20 Fergusson.
Norman
08-09-2001 06:20:09
 Re: Re: 8N\Furgason in reply to Ed-Illinois, 08-09-2001 06:09:47
Ed, Thanks for the come back. The owner isn't aware of this. Not being familiar with these tractors I will have to look this morning when I go to the shop. Thanks again. Later
Norman
Norman
08-09-2001 11:24:12
 Re: Re: Re: 8N\Furgason in reply to Norman, 08-09-2001 06:20:09
Guys, It is an 8N motor and tranny. 8N is cast in the block just below the starter. Tranny has it on it, too. Just the rear end is Ferguson. Thanks for the manuel info. That is about the first thing I do is get all the manuels I can find on a tractor before I go into it. I'll see what the owner wants to do. Thanks again. Later
Norman
