Order Ford 8N Parts Online
8n steering box
Rod
04-02-2000 00:23:36
Could anyone tell me what Ford steering boxes will fit on my 8n? Mine has been cobbled with a saginaw pickup truck box and I'd like to make it at least look original. Anybody have one for sale at a reasonable price?
Claus
04-02-2000 05:24:11
 Re: 8n steering box in reply to Rod, 04-02-2000 00:23:36
There are two types, the early one and the late one that is adjusted with screws on both sides. The later one was implemented on serial number 216989...
Happy Motoring
Claus
Bruce in 100 Mile House
04-02-2000 08:10:26
 Re: Re: 8n steering box in reply to Claus, 04-02-2000 05:24:11
Claus i have a 49 8n 212854 and it has the old style of steering box without the the adjusters.
Are you sure about the s/n that they changed on?
If you are right,then has my box may been changed,but i thought that the newer style of boxes had the pitman arms coming out reversed so that they would not fit.
Claus
04-02-2000 09:36:07
 Re: Re: Re: 8n steering box in reply to Bruce in 100 Mile House, 04-02-2000 08:10:26
Am I sure? No... That is what the FO-4 Manual states on page 20. I have serial number 8N-243167 and it has the late model steering. You never know when you buy a used tractor what is original and what has been replaced. Happy Motoring
Claus
dave#1
04-02-2000 16:14:48
 Re: Re: Re: Re: 8n steering box in reply to Claus, 04-02-2000 09:36:07
third party image
Well, here's a pic of the gear box on my 50 8n, It's the later box.
later,dave
vinc
08-21-2000 19:30:43
 Re: Re: Re: Re: Re: 8n steering box in reply to dave#1, 04-02-2000 16:14:48
my tractor steering box is worn out. this is my first tractor i have just rebuilt the motor. the steering is gone what can i do to repair it. any help will be appricated. vinc
Claus
04-02-2000 16:59:07
Hey Dave, where is the wire to your starter switch? Did you bypass it so that it will start in gear?
Happy Motoring
Claus
dave#1
04-02-2000 17:21:14
 Re: Re: Re: Re: Re: Re: 8n steering box in reply to Claus, 04-02-2000 16:59:07
Yup, I'm a bad,bad boy )-: The switch crapped out, so I by passed it with a new key switch, I guess I should fix it before I run my big butt over one of these days !(-:
later,dave
raytasch
04-02-2000 09:10:34
Do not know about the upgrade sn but the old box can be replaced with the newer box. I have sn 8N 131379 and it has been upgraded to the newer box. Much improvement. fwiw, ray
tlak
04-02-2000 08:07:35
I believe the 600 series will fit but has longer steering shaft.
