Order Ford 8N Parts Online
8n steering problem
ralph delmotte
08-12-2001 18:13:06
The steering wheel sticks and squeaks and is hard to turn. I cant find any way to grease it. Do you need a puller to take the wheel off? Any suggestions?
PAUL8N
08-13-2001 04:48:14
 Re: 8n steering problem in reply to ralph delmotte, 08-12-2001 18:13:06
You need to soak it with liquid wrench for a few days. No puller needed. Leave the nut on but loose by a couple of threads so when you pull on it it doesn't fly off and follow you to the back of the tractor. You could use a little heat if needed, however I didn't need heat after about 3 days of keeping it soaked down. Came right off. Also let us know if it is a new style or old style gear box. You can check your manual if you have one, if not order them from the top of this site. CHEAP, Paul
Claus
08-13-2001 04:46:45
Typical problem with worn thrust bearings. When replacing, replace with genuine metal barrel bearings and not the one piece plastic ones.
Happy Motoring
Claus
bg
08-12-2001 18:38:20
What style 8N steering box? What is your serial number?
