Order Ford 8N Parts Online
8N Temp Guage
Ron Renno
08-17-2001 17:21:38
I recently bought a '52 8N and it has a temperature guage on the lower left side of the instrument panel. Every picture I can find shows only the amp meter, oil pressure, and PTO guage. The temp guage is not connected, and I can't find a place to connect it. Any help?
Ron Renno
08-20-2001 14:12:52
 Re: 8N Temp Guage in reply to Ron Renno, 08-17-2001 17:21:38
Larry..thanx for the photo...the guage on mine is noticeably newer than the amp, oil, or PTO guages. I bought the tractor from an elderly relative, and as far back as I can remember, 35 years or more, it ran off gas...not to say it wasn't converted earlier than the mid '60s...thanx again for the possibility...RON
Larry 8N75381
08-20-2001 09:08:37
Ron,
Check out the gage in the image linked below.
You may have a gage from a kerosene burner. The location is right.
Regards,
Larry
Dell (WA)
08-17-2001 18:45:51
Ron..... ..yer on yer own when it comes to temp gauges on N-Tractors. Not a factory option. Maybe dealer installed, who knows?
Depends upon how ingenious you are. I have seen 4 types of installation. 1) some heads have a flat spot "boss" that on some Ford 4 cylinder industrial engine installations has been drilled and tapped. 2) some have found enuff "addaptors" to install in the block drain behind the oil filter. 3) some have found "1/4 moon rubber shim" that has a notch that they can fit under the cylinder head radiator hose clamp. 4) some have just cut the upper radiatior hose in half and installed a metal pipe with a brazed in fitting.
Since the N's radiator system is claimed to be overly exceeding needed capacity, most don't bother worrying about a temp gauge..... ..Dell
Ron
08-17-2001 19:56:58
 Re: Re: 8N Temp Guage in reply to Dell (WA), 08-17-2001 18:45:51
Thanx for the info Dell...that explains why I haven't seen one in pictures...no problems overheating, so I'll just leave well enough alone. Thanx again.....RON
