Combination Blade
Sal
08-19-2001 16:17:22
Is there such a thing as a combination blade...a back blade/box blade?...able to convert back and forth.
I heard someone talking about such a thing once, but I have never seen one.
Thanks/Peace
Sal
Mike S
08-20-2001 05:46:14
 Re: Combination Blade in reply to Sal, 08-19-2001 16:17:22
I've never seen a box blade that could be turned at an angle but you can get one from Gill that is called a rollover blade so you can both push and pull as needed. It also has scarifier teeth that can be used to rip up the soil. I have an IMCO box blade that has both a front and back blade, the blade is hinged so that it can be lifted up out of the way or let down to smooth soil when going forward. It also has some scarifier teeth that can be lowered. I have an Arps blade for doing angle work.
Ed Gooding (VA)
08-19-2001 17:45:22
Hey Sal. Arps made a backblade with detachable side plates. It was intended for snow removal, and not for grading/material-removal like a traditional box blade. Did not have scarifiers. Here's a couple of scans from an ad flyer:
third party image
third party image
Hope this helps..... ..... Ed
'52 8N475798
Jhill
08-20-2001 07:24:09
 Re: Re: Combination Blade in reply to Ed Gooding (VA), 08-19-2001 17:45:22
I have one of these blades with the side extensions. It won't move as much dirt as a box blade but it works pretty good. It is a well made blade not like the TSC crap they sell. I have the only set of side extensions I have ever seen but a goot frabricator could make a set quite easily.
Ed
11-22-2003 10:15:18
 Re: Re: Re: Combination Blade in reply to Jhill, 08-20-2001 07:24:09
Looking for a set of side extensions for an Arps AB-11 back blade.
Anyone got one?
