Hi Randy. >> Wondering if anyone would know if a Dearborn 14-3 or 14-3 side-mount sickle highway mower made for an 8N will fit on a 9N/2N, << Not without some customizing on your part. Parts of it mount to the running board mounts on 8N's. The frame mounts to transmission housing bolts on both sides and I don't know whether they are the same on 9/2 N's. You need position control to raise it over obstructions while mowing, and I'm not sure if Zane's Thang will overcome this or not. It looks to me like the 14-3 and 14-4 (5'/6' cutter) were introduced specifically for the 8N. Will the seller let you take it on approval, so you can check it out and see if it will mount up, and return it if it won't? I've got an Assembly & Operating Instructions manual for it, but it's really in rough shape. Readable, but lot's of grease and dirt stains on the pages. A previous owner used the heck out of it. I can scan it and email it to you. The N-Newsletter Archives also has it, and you may be able to get a more readable copy from them for copying and mailing costs. Hope this helps..... ..... Ed '52 8N475798
