Hi, this is a great resource, thanks for all the info I've already gotten in just three days of peruising the messages. I just got my 8n about 10 days ago and have only done a little blading, I am really ignorant about all things tractor. I decided I needed the stabilizer bars, but after getting them, I could not for the life of me mount the blade back on. I would get to the last pin, either the axle/stab. pin, or the lift/blade pin, and it would be so slightly off, less than a 1/4 in. I tried all kinds of ugly things to get it on, like a 5+ ft, 2 in pipe! Any way, I finally realised what an idiot I was, I had the pins on the lift arm backwards, sticking in istead of out!(this is a really obvious, stupid newbie thing to do)So, we are talking a 3+ hr on friday, and 3+ hr on saturday ordeal. Then, after correcting the rediculous cockpit error and mounting the thing, I was so excited, it was time to start working again, finally. Well, I got it started and drove about 30 ft when the engine died. Could not start it for the life of me, you can really crank that sucker a long time without killing the battery. Lotsa of pondering and trouble shooting ensued, getting gas to engine ok, no shorts that I could find, power getting to distributor terminal, etc. There was no spark from any plug wire, must be distributor or coil??, I got that figured out, but, I also found that I have an 8V, negative ground system??? OK, here is the real problem, in tracing wires etc, trying deperately to figure out for sure what was going on, I found that the wire to the coil, which is supposed to come off of one leg of the resistor/terminal block, was wired to the middle terminal, the one not on either side of the resistor, there was nothing attached to the reistor leg that the coil was supposed to attach to. Can anyone tell me the implications of this? Is this the probable cause of the failure of the dist/coil after only about 5-6 hours of tractor operation since I bought it? I put it the way it is supposed to go, but still no spark, so my brand new toy is sitting blocking the driveway, and I have to leave town for a couple of days. Hope this wasn't too long a post, thanks rob ps: I am sure you will be hearing a lot more form me.
