Bent radius rods.
OUTim
08-21-2001 18:39:46
There is a 1946 2N up for auction on E-Bay. It has 2 "high arc" radius rods that show up on the picture. Is it possible to hit something hard enough to bend them like this ? Or are there other causes ?
Bill W.
08-22-2001 10:38:01
 Re: Bent radius rods. in reply to OUTim, 08-21-2001 18:39:46
the answer is "yes." And you can straiten them with a 9 lb hammer if you know how. Make yourself a trough with two two by fours nailed against a two by two and lay the rods edge up. Frail away with great deliberation and you most likely will straighten them. Dont strike the rod in the same place twice too often or you will seriously dent them. Vary your hit locations. I have straigtened some which were bowed from side to side by simply laying them down on concrete and hitting properly. Another way to straighten vertical bowes is the use a healthy hydraulic press with the rod held firmly in place. Good luck.
DaBrow
08-21-2001 19:38:33
The answer to your first question is ...yes you can!!
Thompson8N167346
08-22-2001 06:52:52
 Re: Re: Bent radius rods. in reply to DaBrow, 08-21-2001 19:38:33
I'll second that!
