Ballast resister?
Ronof ohio
08-23-2001 10:57:39
I know that another question about a 6v to 12v conversion is redundent, but heres another one. I recently converted after spending many frustrating hours and $ on 6v regulaters that just didn't want to work. The generator seemed to work at times. But when I took the gen. to a repairman and he said that either rebuild the gen for $125 or convert to a single wire alt. for $75, it was a no brainer. I did replace the coil with a 12v and so far I have about 8 hours 'bushhogging' time and no problems, even tho I ran the coil directly off the battery side of the volt meter with no ballast resister in series. I don't want to ruin the coil, but there seems to be several opinions as to whether the ballast resister is necessary. Also, is the 'ballast resister' everyone refers to the same as the existing resister that is mounted on the inside firewall. It would be no problem to put this resister in series if necessary but the last time I tried to start it with the resister in series, it would not start. I have been toying with the idea of using a toggle switch to remove this resistance during starting and switching it in after starting the tractor. I've heard that there are oil pressure switches that do the same thing. So, what do you all think? (by the way, its a 42 with front mounted distributer)
Dell (WA)
08-23-2001 12:53:39
 Re: ballast resister? in reply to Ronof ohio, 08-23-2001 10:57:39
Ron..... ..yas been luckies... A frontmount 12 volt coil that hasn't lunched its guts without the protection of a current/heat limiting resistor. Commonally miss-called a "ballast resistor."
My advice, if'n you really have a 12 volt frontmount ignition coil is to use a double (side-by-side) real OEM ballast resistor installation. Just parallel a 2nd one with the original ballast resistor on the backside of the dashpanel. If'n you don't understand parallel, ask a local highschool radio/computer geek to draw it out for you.
The coil problem is internal, too much current causes it to overheat and melt the insultative tar and short out some of the internal windings thus reducing the sparkies output. Therefore, to prevent overheating, we limit the current flowing thru the coil primary by using a mis-named ballast resistor. Just as many ask for a "Kleenex", when you really are asking for a disposable paper snott-ragg, so it is with this mis-named "ballast resistor".
Understand, a real ballast resistor is different from a normal resistor BUT we can use the N's ballast resistor to solve our coil problems if'n ya pays attention and do it like yer told. N-Tractor ballast resistors are relative eazy to get and relative inexpensive, that is why I am recommending this proceedure for the front mount 12 volt ignition coil scheme.
Bottom line, 2 ballast resistors in parallel, will provide the desired coil current/internal heating control and your 12 volt front mount coil will live a long life.
As a double check, after you have completed your wiring, you should read about 10 volts at the coil terminal (9 min, 11 max) with the points closed and battery volts with the points open. If'n you read battery volts all the time, you have miss-wired the ballast resistor, and if you read about 8 volts, you have miss-wired the parallel resistors into series (like flashlight batterys). 8 volts won't kill your coil, but it will kill yer sparkies..... ...Dell
chuck
08-23-2001 12:06:35
Ron(?), I have had a 12V coil on my 51 for about 5 years without a ballast resistor with no problems. I also have a "pointless" ignition module in the distributor. This makes the ignition system "Problemless". I put 35-50 hours a year on the Proofometer clock.
chuck
436244
