Order Ford 8N Parts Online
8N broken plunger
8N Ed in TX
08-27-2001 18:01:57
I have not found this in the archives. In 5 years I have broken 2 plungers (the shaft that fits inside the plunger guide that fits inside the main control spring) This happens during bushogging on somewhat rough terrain. I have a '49 8N with a 2 hole rocker in which I use the bottom hole to attach my top link. The break occurs right at the rim of the yoke. Why am I breaking these and where can I find another one (my last source can't find any)? Can this be welded? Thanks for the help.
dave#1
08-27-2001 20:34:12
 Re: 8N broken plunger in reply to 8N Ed in TX, 08-27-2001 18:01:57
Is the mount for the top link on your bush hog rigid or slotted/hinged? It sounds like yours is rigid and when you go over unlevel ground it's "Pile drive'n" your top link into your rocker shaft/yoke ?? If it is rigid stop useing a top ling and start useing a chain, you can buy a chain allready made for this task or just make one.
HTH
later,dave
