Order Ford 8N Parts Online
Roto-tiller with an 8N
Robert in Alaba
08-27-2001 20:46:55
I was just wondering has anyone out there ever tried to pull a tiller with a 8N? If so what kind?
bj/8N/mt
08-28-2001 06:15:37
 Re: roto-tiller with an 8N in reply to Robert in Alabama, 08-27-2001 20:46:55
What he [Dell] said.
Your 8N ain't faster than a speeding bullet. It ain't more powerful than a locomotive. It won't leap tall buildings in a single bound; and, It won't roto till. Although it is theoretically possible to build an 8N that would run slow enough with the PTO rpm high enough to make this work--see a post I did in the archives last spring--the cost would far exceed the benefits. If you need to till make a trip to the rental shop and rent a rear tine tiller.
YOur mileage may vary
Dell (WA)
08-27-2001 22:23:28
Robert..... ...not recommended. The N is too high geared for rototillering without the rare and fragile "Howard" aux gearbox. Sherman aux gearboxes don't do it.
Howsomever, the N is a 2-bottom plowing fool.
Many years ago, I saw several 3-point aux engined rototillers that worked on N-Tractors but I don't know what brand or anything else except it was in Lodi Calif 1973.
Usually every spring there is a spate of inquiries about rototillering. You might want to check the "archives" at the top of this great N-Board..... ...Dell
