8 N compression test now what?
Robert in Alaba
08-28-2001 19:22:17
Ok Dell or Dave or whoever, I am having some problems with The ole red belly.
1st- Knocking from #4cycl.
2nd- oil on plug from # 3 cycl.
3rd- losing power when hoggin also started backfiring some, starts good,idles good but under a load tries to quit it does this going up a small grade whether cutting or not.
Did a compression check.
Results: DRY #1 90 psi Wet #1 90 psi #2 100 psi #2 110 psi #4 89 psi #4 110 psi #3 100 psi #3 110 psi A little black smoke or burnt place on head just above the manifold.
What do ya think guys?
Darrel (ok)
08-28-2001 20:18:11
 Re: 8 N compression test now what? in reply to Robert in Alabama#245040, 08-28-2001 19:22:17
It seems to me that a reduced point gap could cause backfiring. When I first got my 49 8n the wiring was bad and it would only start by pull starting. We only did this about two times but it backfired real loud through the exhaust. When I did the conversion, I took the distributor off and cleaned it. If I remember right, the point gap was down to about 4 thousandths. I did not have a manual at the time I reset the points, so I set it to 19 thousands. I have not had the distributor off since, about a year and a half now, but I have not had one speck of trouble from it. Hope your luck will change.
Dell (WA)
08-28-2001 19:37:07
Robert..... ...Ford specs sez: 90 psi min. All your cylinders exceed the min. On a good engine, I would expect to see about a 10 psi increase "wet".
Your knock could well be a hole in the exhaust gasket.
But this doesn't address your "weak engine" problem. A tune-up would be a good place to start. The governor should respond to the load of going up a hill, it sounds like it doesn't. Do the I&T FO-4 governor adjust proceedure.
The backfiring sounds like poor ignition timing, or bad centrifical advance. Lack of power and backfiring is a timing issue. Check your centrifical advance weight mechanisms per your I&T FO-4 proceedures.
Bottom line, I think you have a good engine, donna mucka round, just fix the ignition and governor..... ..Dell
