Order Ford 8N Parts Online
8N centrifical advance weight mechanism
Robert in Alaba
08-28-2001 21:59:17
Dell the black smutt on the outside of the block is where the knocking is coming from.
O yeh whats this centrifical mechanism you are talking about? points or what?
? Should there be a gasket where the gov. bolts to the motor?
By the way do you guy's ever sleep?
I sure appreicate all the help on this site.
THANK YOU GUYS,YOU ALL ARE A BIG HELP
Robert in Alabama with a 1949 8N # 245040
Dell (WA)
08-28-2001 23:44:21
 Re: 8N centrifical advance weight mechanism in reply to Robert in Alabama, 08-28-2001 21:59:17
Robert..... ...If'n ya gotts bad ears like me, the putty-putt of an exhaust leak with the black sooty smuge could sound like valves knocking.
Distributor has a centrifical advance mechanism mounted underneath the plate that the ignition points are mounted on. Get out your I&T FO-4 and study it.
p/n 9N6022, gasket, governor to timing gear cover.
HTH..... ..Dell
