PTO Shaft Connection
Sal
08-31-2001 15:38:40
What type of pin/bolt should I use when I connect my Bush Hog to my 8N PTO? Should I use a low grade bolt or some type of pin?
Thanks
Peace
Sal.
Dell (WA)
08-31-2001 21:24:22
 Re: PTO Shaft Connection in reply to Sal, 08-31-2001 15:38:40
Sal..... ..the shearpin bolt is grade 2, cheapest and softest bolt there is. I want the shearpin to break before my brushog guts do. And while I scalp rocks in my rocky pasture while mowing, I've only replaced the shearpin once. (knock on wood)
But more importantly, you must have an Over Running Coupler (ORC) on your N-Tractors PTO shaft. The ORC prevents all that brushog inertia energy from backfeeding into the tractors tranny when you clutch to slowdown to go around the barn corner, fence post, creekbank, irrigation canal, wifes car (don't ask) and surprise it doesn't slow down. The ORC also prevents expensive noises in the tranny. $60 cheep, gettcha one..... ..Dell, the self-appointed ORC safety preacher
dave#1
08-31-2001 17:40:49
I "Think" Grade 3or 5 ?
Sal my man..... What's with sign'n your name with this "Peace" crap???
You ain't go'n to tell us you wear bell bottom pants, beads, flower's and hair down to your waist are ya ???
ROFL Have a good one bud !
later"Belch"dave
Good deal !......dave#1
09-01-2001 05:41:32
 Re: Re: Re: PTO Shaft Connection in reply to Peace Dave...Sal, 08-31-2001 19:47:24
Good deal Sal , Just had to make sure, cause I found out the hard way about that "Tyman" clown !
ROFL
Have a good one
later,dave
Hmm, that kinda shut Dave up
09-01-2001 00:58:03
Kevin CO
08-31-2001 16:59:40
Sal,
It is usually a bolt. Grade 3 if I'm not mistaken. I think they have a desired length too, not too long.
Your local NH dealer or other farm place can set you right.
trial and error
08-31-2001 16:35:56
first off get yourself an overriding clutch, otherwise that bushhog could push you over an embankment. I am sorry to say I know of that happening and they aren't with us anymore.
