Order Ford 9N Parts Online
Temp gauge on 9N-good idea
Phlash in OK
09-02-2001 12:40:32
I was bushhogging Friday evening, smelt a little anti-freeze, saw a little steam, then she blew the top out of the radiator. Then I found the broken fan belt. When I repair it I plan to install a temp gauge. Where have you 9Ners put the gauge? Do you cut a hole in the aluminan dash? I have oil press gauge on one side and ampmeter on the other. Do you recommend a mechinal or electric sender? Be glad to hear your advice
REDNECKMATT
09-02-2001 19:25:22
 Re: Temp gauge on 9N-good idea in reply to Phlash in OK, 09-02-2001 12:40:32
My dash was already busted up so put it there. I used mechanical one, took the petcock out of the side of the block and the tip threaded right in. Did that 7 years ago with no problems.
Tom-Pa
09-02-2001 13:37:13
I would not destroy the dash and ruin any restoration efforts in the future. I would make a bracket and install it somewhere you can see it and that way it can be removed for restoration if so needed... Good luck
Tom-Pa
RICKWI
09-02-2001 18:57:38
 Re: Re: Temp gauge on 9N-good idea in reply to Tom-Pa, 09-02-2001 13:37:13
Run the puke tube out where you can see when the brown overflow starts. Made it the first 60 years with a gauge :)
