No spark
49-8N
09-02-2001 16:17:00
Had been brush-hogging for about 45 min. and tractor was starting to running rough, missing. I hit a log and killed the engine. wouldn't re-start. Let cool, still no fire, no fire to plugs but alt. needle twitches when cranking. I'm thinking coil but would appreciate this board/s advice
NH Steve
Hunter
09-02-2001 19:02:07
 Re: No spark in reply to 49-8N, 09-02-2001 16:17:00
Check to see if ya got fire coming to the coil with the key on of course. If ya got fire there then check if you have fire at the little spring thing on bottom of coil. One time I had to brighten up the point on my little coil spring.
49-8N
09-03-2001 07:36:38
 Re: Re: No spark in reply to Hunter , 09-02-2001 19:02:07
Well what do you know.. fire from the "little coil thing" was good. Pulled the cap and don't ya know the rotor was all broken up. Thanks for your help, should be back hoggin soon
NH Steve
smokie
09-02-2001 16:26:05
ya are thinkin rite.
but check dell standerds and make shure every is clean brite and tite before ya spend the bucks on the coil.
goodluck
