I agree ith scott that the Transmission of the Nseries tractor is geared too high for using a tiller. However it is perfect for a one or two bottom plow and a disk. Note of caution on the loader. In addition to the need for an auxilliary pump to run it, or need to modify the existing hydraulics, the N chasis wasn't designed to hold the extra weight induced by adding a loader. The N does not have power steering, so turning the wheels with a load in the bucket becomes a chore. Also, the weight in the loader bucket rests on the front axle, which is connected to the tractor with a king pin. The king pin does fine supporting the weight of the tractor, but the added weight of a loader can cause it damage. However, for the price, the N series tractor provides a lot of service. Also, they hold their value very well so that if you needed more tractor in the future, you would more than likely be able to get out what you paid for it. Good Luck!
