What is it ?
Sam
09-04-2001 18:59:23
Son bought a tractor (FORD ) and trying to figure out year . Only number is on engine and is 9n215915 . He has a parts book and looks like somewhere between 1939 and 1947 .The only other number I could find was on the rear of engine and is J 268 8N D
any info would be greatly appreciated .
Larry 8N75381
09-05-2001 08:07:09
 Re: What is it ? in reply to Sam, 09-04-2001 18:59:23
Sam,
You had better take another look, something doesn't match. A 9N (or 2N) engine block should have the serial number STAMPED into a flat boss by the head on the left AND the number should start with 9N - for both models. An 8N engine block (except for the first ones in 1947) should have a RAISED CAST 8N at the rear near the starter, like yours. Also in that location is a raised casting date indicating when the block was cast, which you wrote was J 268. With J standing for Oct. and the last digit for the year (8 = 1948) your block was cast on Oct. 26, 1948. The last 2N (9N s#) was made in June 1947, a year earlier.
If you missed the first digit (the 8) and thought it was a 9, then the rest of the serial number looks not too far away from the tractor assembly date when the S# was stamped in. I estimate the S# 8N215915 to have been assembled at the end of March or begining of April of 1949. That is not too far away from the cast date of the end of Oct. '48. The block had to be machined before it could be assembled. And if the engine internals were assembled (very likely) before it was brought to the final assembly line, that would take more time.
bg has given you the link to a good site to check the identity of the tractor. AND for that matter, the identity of various components as they were changed throught the production run. After 50 years, it is not uncommon to have "mix and match" tractors because of the interchangablity of the various parts over the years.
Would like to know what you find out - repost here on the board.
Regards,
Larry
bg
09-04-2001 20:04:55
Go to this site and study it. Then look at your tractor and see if you can match information with what you have. There are differences in models, some obvious, some subtle. Most likely, you have a hybrid, based on your description.
Dell (WA)
09-04-2001 19:45:16
Congratulations, you have the bragging rights to a 1946 2N engine. All 2N's engine s/n start with 9N. The other numbers are casting dates and I don't care to remember how to read 'em..... ..Dell
