Valves and Head gasket
Robert in AL 8N
09-04-2001 20:46:46
What should I look for with the valve inspection plates removed? Also I have the manifold removed and need new gaskets.Should I remove the Head and if I do What should I look for. I have never done this before but am familar with this 8N and have done some other work on it in the past.
Your HELP IS appreciated
Robert, Needing to get her running again cause igonna bush hogg
Safetycop
09-05-2001 06:45:09
 Re: Valves and Head gasket in reply to Robert in AL 8N#245040, 09-04-2001 20:46:46
Forgive me if you already know this: Before you start hoggin' make sure you have an ORC (over-running clutch)
Its a device that goes between the PTO and the hog and prevents the blades momentum from pushing the tractor.
Hoggin without one is just plain DANGEROUS !
Dell (WA)
09-04-2001 23:12:14
Robert..... ...with your valve covers off, check your valve clearances per I&T FO-4 manual.
Only reason to change your headgasket is if'n your having somesort of a problem with it. The only way to determine if'n ya gotts a problem with headgasket, is to do a compression check. First dry, then wet. Writes all the numbers down. If'n the numbers donnna make any sense, post 'em on the N-Board anna you'll get lots of opinions.
Remember there is a special pattern and sequence to use to tighen the headbolts. Check your I&T FO-4 manual, $25 cheep, gettcha one and read it..... ..Dell
