I just replaced the coil on my 8n (front mount ). At first --no spark at plug . I measured the voltage at the terminal on the coil --6 V . Turned the engine over with meter on coil -- no change, still 6V . Took the coil out -left the wire on ,measured the voltage at the little spring --6V . Touched the spring to ground --nice spark at HV lead . Then I bent the little spring a small ,calibrated amount -maybe a 1/8 inch -- put it bacxk in ---Hit the starter button and away it went --started right up . The problem was -- the spring was not making contact with the point connection in the distributor . I rechecked the voltage at the connection on the coil -- it fluctuated as the engine was cranked over . By the way --- it is not just A coil --- but a transformer with a low voltage primary winding of relatively few turns ofheavy wire ,over which is the secondary winding of a large number of very fine wire .
