Off the subject....but a question for Dell or Zane or anyone....
Roland Jackson
09-08-2001 17:40:26
Yesterday, I gave $50 for a really nice E-Z-Go Golf Cart. It has been setting in the old John Deere building, in Dodge City, for about 10 or 15 years. Anyway, all six of the 6 volt deep cycle batteries were completely dry. I filled them with distilled water and charged each one individually. As it turned out, I wasted some really good distilled water. Now, I need to buy some golf cart batteries. My question is.... (1) Would three 12 volt deep cycle batteries work as well as six 6 volt deep cycle batteries? (2) What is the best brand of battery to buy? (3) What should I expect to pay for the batteries? This golf cart is going to be my wife's "Granny Mobile" for our future grandkids, so I need help in fixing it right. I wouldn't want to get in big trouble, you know! I appreciate your expertise and help.
Scott Houtex
09-10-2001 07:07:20
 Re: Off the subject....but a question for Dell or Zane or anyone.... in reply to Roland Jackson, 09-08-2001 17:40:26
My wife's uncle just gave her an old EZ Go
when he sold his ranch. Here is a link to
a site that sells all sorts of parts for
golf carts. I have ordered some parts but
have not received them yet, so I don't know
how good they are yet.
ZANE
09-09-2001 18:47:07
I think that the reason that the cart came with 6 volt batteries is so that if one cell dies the 6 volt battery is cheaper to replace. Also the 6 volt battery may be able to store more amperage by giving more capacity. One disadvantage to using 6 volt batteries is the fact that you will have twice the number of cable connections to corrode. You know what happens in a system with more than 12 volts when you get a bad connection and the connection arcs. It goes PSSSST and the post is gone from one of the batteries. It can even cause an explosion of the hydrogen gas that the batteries generate.
I used to work on golf carts too in industry as a master mechanic on construction etc. and if I had to choose between the battery and the gasoline instant start golf cart I would choose the gasoline. Electrics are really great when they are fully charged and all the connections are bright and good but when corrosion set in they can be a pain to maintain. Batteries do corrode.
To answer your question you can use the 12 volt batteries just as good as the 6 volt ones and they will be just as effecient if you have the same amperage reserve.
Roland Jackson
09-08-2001 18:30:20
Ford Man, thanks for the reply and help, . The battery charger did come with the golf cart. It is the orginal unit that has E-Z-Go printed on the case. I plan on replacing all the battery and connecton cables in addition to the batteries. Also, all contact points (key switch, forward / reverse lever, solenoid, and posts on the motor look like they could use some attention, so I will be looking in to that. Is there anything else that I may be missing?
Ford Man
09-10-2001 09:20:54
 Re: Re: Off the subject....but a question for Dell or Zane or anyone.... in reply to Roland Jackson, 09-08-2001 18:30:20
Roland,
I am a little rusty on this but here goes ...
First make a wiring diagram and keep it in a safe place . It will save you lots of headache later .
You should be able to clean up your battery cables . I remember them being really heavy .
I would not bother replacing any switches just yet . Check them with a tester first . On second thought , you had better check that motor 1st. before you do anything else ! A quick check would be to jack up the rear end and hook jumper cables to it and see if it turns .
Clean the "sweeper" contacts with fine sandpaper . You will see them under the seat . They are hooked to the gas pedal linkage and have copper contacts . This is a frequent problem area .
You can check a solenoid by jumping accross the terminals ( with the rear end jacked up ) . If they are bad , try Napa for a replacement .
We often found the battery box to be in bad shape and welded us up new ones from angle iron .
Hope this helps !
Good Luck !
Ford Man
Ford Man
09-08-2001 18:09:24
Roland,
I worked on golf carts for about 4 or 5 years with my Grandfather before he died in 1985 .
Your best bet is to stick with 6 volt golf cart batteries . Try your yellow pages to see if there is a golf cart repair service near you . We refurbished a lot of carts and sold them to farmers . You might find someone who does that near you . You can also try Sears . They used to sell Exide brand golf cart batteries .
You say that you charged each battery individually . Did you also get a charger that plugs into your golf cart ? If memory serves me , they will charge one up in about 8 hours .
Let us know what you find .
Ford Man
