Carb adj. help needed
49-8N
09-09-2001 15:06:34
I removed and cleaned the carburetor looking for a problem, turned out to be a rotor problem. now it's running rough and stalls a lot. can someone tell me how many turns out each of the 2 needles should be set at? thanks
498N - thanks for the advice
09-10-2001 08:43:49
 Re: carb adj. help needed in reply to 49-8N, 09-09-2001 15:06:34
Thanks for the tips, I'll let you know how it works out
Bob (KY)
09-09-2001 16:35:45
Here's a link. Good as any, Better than most!
doug-8n
09-09-2001 16:30:53
When I went through the carb on my 8n, the I & T manual said to close the needles and then open one full turn. Once running and to operating temperature, the idle needle should then be turned in until the engine falters, then turned out until the engine runs smoothly. The main needle (large one towards radiator) should be adjusted under load by repeating the same process. Turn in until engine falters, then turn out until engine runs smoothly. One note in the manual indicates that if the engine hesitates or backfires when picking up a load, turn main needle open 1/8 turn to enrich the mixture.
