Zane's Lye Stripper or What?
Al in PA
09-09-2001 19:56:52
I've got my eye on a Ford 4000 that is going to be sold at an estate auction. The drive train has some nasty rust to be removed before painting. It has been stored in a wagon shed and it has been the target of many pigeons and a few male cats left their scent on it. My question is this: Will Zane's lye paint stripper do anything to help attack the rust or is there a commercial product that will do the job? Has anyone use Gempler's Rust Converter - does it work? Thanks for any suggestions.
Bill W.
09-11-2001 17:13:44
 Re: Zane's Lye Stripper or What? in reply to Al in PA, 09-09-2001 19:56:52
Al: Zane's lye stripper is just that; a stripper which basically disolves and helps strip old paint off. It doesn't do much for the rush other than remove the surface flakes, etc. Your best treatment for rust is to wire brush or angle grind with wire brush and then treat with rust treatment such as Rust Seal. It works good and will prepare your surface for a good primer or regular paint. You must remove as much of the surface rust as you can. good luck.
Al in PA
09-11-2001 17:19:44
 Re: Re: Zane's Lye Stripper or What? in reply to Bill W., 09-11-2001 17:13:44
Thanks for your response. You confirmed my suspicions, but I needed to find a product to treat the metal after removing surface rust. Thanks again.
