Ford Plow ?
raymd
09-10-2001 11:37:04
Going to look at what is suppose to be an original
Ford plow 16" one bottom for an 8n. Is there a way
to tell for sure if that's what I'm getting?
Unique features ? Thanks !
Ed Gooding (VA)
09-11-2001 03:30:25
 Re: Ford Plow ? in reply to raymd, 09-10-2001 11:37:04
Here ya go, Ray. If you get it, I can send you the full blown parts explosions and lists.
third party image
Regards..... ..... Ed
'52 8N475798
WHEELINGARROW
09-10-2001 16:46:10
CHECK WITH THE GUYS OVER ON THE IMPLEMENT ALLEY DISCUSSION FORUM. JUST CLICK ON THE DISCUSSION FORUMS ON THE LEFT SIDE OF THIS PAGE. HAVE FUN WITH YOUR NEW PLOW. SHINE IT UP REAL GOOD AND THEY WILL REALLY DIG.
Gene Miller '48 '52 8N's
09-11-2001 07:36:30
 Re: Re: Ford Plow ? in reply to WHEELINGARROW, 09-10-2001 16:46:10
Please PLEASE stop SHOUTING!!! It makes my head hurt! Hit that CAPS key and please turn them off!!!
09-11-2001 07:34:21
Ed Gooding (VA)
09-10-2001 13:38:28
Hi Ray. If you get lucky, there will be a metal Dearborn tag/plate attached to the frame with the model and serial #'s. I'm at work now, but can send you a picture from home in the morning if you want.
Regards..... ..... ..... Ed
'52 8N475798
raymd
09-10-2001 14:00:37
 Re: Re: Ford Plow ? in reply to Ed Gooding (VA), 09-10-2001 13:38:28
A picture would be great, thanks ! I will look for
that tag.
Ed Gooding (VA)
09-10-2001 13:28:22
'52 8N475798
noff
09-10-2001 12:18:32
I just picked up some CAT-1 equipment and with it was an original Ford Post Hole Auger. I know it was original because there was a plate on the sid with Ford and the serial and part number on it.
Along with 4 pieces of Dearborn equipment. All with plates, serial and model numbers.
DaBrow
09-10-2001 20:51:09
 Re: Re: Ford Plow ? in reply to noff, 09-10-2001 12:18:32
You're trying to make me ill,aren't you? At the very least, light green....DaBrow.
noff
09-11-2001 13:02:08
 Re: Re: Re: Ford Plow ? in reply to DaBrow, 09-10-2001 20:51:09
Would it make you real green to know that I got all five pieces: disc, chisel plow, bucket, blade, and auger for 500.00?
