Engine
Robert
09-12-2001 17:19:25
FIRST ---GOD BLESS AMERICA AND ALL THE CHILDREN WITH LOST PARENTS TODAY---
I have just rebuilt carb. and while trying to start (which was a problem)I had the breather pipe off at the carb. and I heard a pop from the motor and also a hard vaccuum from the carb air intake. When I turned it over the next time a I heard a grinding noise from the motor.
Before rebuiding the carb. I had a pinging noise from #3 cyclinder. I found a bad manifold gasket/ replaced it also.Then repalced carb. NOW THIS I had a 49 8N that ran pretty good. It hadn't been worked very hard in probably 6 years until this past summer. Where do I look? I am laid off from International Paper and dont have alot of money for parts.Please help.
Sorry so long just flabergasted right now and don't know where to start.
Thanks for any help this forum has helped me alot
Ps I had good compression before all this also. Right now scared to turn over engine.
Thanks Robert
smokie
09-12-2001 17:47:25
 Re: engine in reply to Robert , 09-12-2001 17:19:25
start with the ezy stuff pull the head and see what ya see pull valve covers at the sametime valves could be the suckin and popin but the grindin scares me alittle this is just a startin point cous ya allways start at the top
Robert Help Dell/Claus/Dave/Doug/Ed
09-12-2001 18:55:04
 Re: Re: engine in reply to smokie, 09-12-2001 17:47:25
I checked compression it's OK. Checked starter/ring gear it's ok. The grinding I'm hearing is coming from near where the ring gear is at. At the back of the motor. Could this be a bearing or what?
Thanks Guys
This info has been a lot of help for my dads OLE RED BELLY.
ROBERT 8N 204054
Robert
09-12-2001 20:23:14
 Re: Re: Re: Re: engine in reply to Dave Smith, 09-12-2001 20:13:25
I turned the ring gear with a screwdriver. I couldn't feel a drag or any unusal noise when doing this. I ran the starter on the bench. It did ok. I was wondering how far the bendix should engage? I replaced the ring gear about 1 yr. ago it looks ok. The starter shaft looks like it has some warpage to it a little. I havent tried using the clutch while starting. If I have good compression does that exclude anything inside the motor? Thank you very much I need this help.
Robert 8N245040
Dave Smith
09-12-2001 20:28:12
 Re: Re: Re: Re: Re: engine in reply to Robert , 09-12-2001 20:23:14
You say the starter shaft is warped. I think you found you're problem. Remove the starter and tow start it to be sure if you want but I'll bet that is it.
Dave <*)))><
Dave Smith, PS
09-12-2001 20:33:57
 Re: Re: Re: Re: Re: Re: engine in reply to Dave Smith, 09-12-2001 20:28:12
I would replace the starter and bendix both. The bendix is probably damaged by the bent shaft. About $150 for a rebuilt starter and a new bendix.Get the positive drive bendix and DO NOT extend it before you install it. Or you will be sorry. Dave <*)))><
Dave Smith, Also
09-12-2001 20:44:08
 Re: Re: Re: Re: Re: Re: Re: engine in reply to Dave Smith, PS, 09-12-2001 20:33:57
Before pulling the starter all the way out put a nut on the through bolt to keep the back cover from coming off. If the cover comes off far enough the brushes will come off the comutator and they can be a bugger to put back on.
Dave <*)))><
Robert
09-12-2001 21:02:48
 Re: Re: Re: Re: Re: Re: Re: Re: engine in reply to Dave Smith, Also , 09-12-2001 20:44:08
when I try and start the ole 8N . Push the start button if it doesn't start in a couple of seconds the bendix will disengage and starter will hum . Is this normal? Not like my truck where you can keep running the starter as long as you trying
Tow start
09-12-2001 20:50:18
What exaxtly is a tow start? I ran the starter on the bench. Am I Missing somthing
Thanks
Dave Smith
09-13-2001 04:52:24
 Re: Re: Re: Re: Re: Re: Re: Re: Re: engine in reply to Tow start, 09-12-2001 20:50:18
Chain the N to you're pick up or whatever and tow it. Put the tractor in 3rd. gear When it is moveing let the clutch out. Once it is running put the clutch in and take it out of gear.
Dave <*)))><
Mikey
09-12-2001 22:53:20
Tow Start?
That's what we do to a John Deere before a tractor show.
Mikey
