Won't start
Robert
09-13-2001 13:52:17
Ok Guys replaced starter. She'll now turn over. To begin I rebuilt carb, replaced distributer cap,new points,set timing,per fo-4,Once she starts she run's ok. But trying to start is rough,backfiring real bad after turning off then trying to restart. When I put it in gear and try to run down the road it wants to quit. It will idle good once started and is smooth to increase rpm's. Just hard to get started. What do ya think Thanks
Dave Smith
09-13-2001 17:01:04
 Re: Won't start in reply to Robert, 09-13-2001 13:52:17
Robert, I take it you're grinding noise was the starter bendix. Try what Doug said with you're carburator.
Dave <*)))><
doug-8n
09-13-2001 13:59:54
After stopping the engine, take off the air cleaner tube near the carb. Leave the gas tank valve open and see if any gas is running out of the carb. If gas is present inside the air intake, your float is stuck or improperly adjusted. This will cause the engine to flood when you try to restart the motor. Also, follow the I & T manual to be sure the carb jets/needles are properly adjusted.
49 8N sorry Robert
09-13-2001 13:54:33
49 8n
