Interesting. Another possible clue is that the engine was equipped with Autolite #303 plugs instead of #437s. That may have been because of clearance. What got me started on all this was a slipping #1 sleeve which is why I originally did the teardown. Plus I wanted to do a 12v convert. Everything inside (e.g. bearings, sleeves) looked pretty good & it was obvious there had been a rebuild at some point. Before I tore it down it was hard to start but ran well when warmed up (except for the noisy sleeve). Unfortunately I neglected to first make note of things like timing settings, gap settings, plug wiring (could it have been staggered?), head gasket thickness, etc. FYI I compared the timing of the old and new distributors at same RPM (1500 +/- ?), same point gap (.010) and same timing setting (middle). The new dist. was somewhere around 30 deg. BTDC; the old one was almost right on TDC. And if I run the retarded dist. at .008 gap & timing screw fully retarded, it runs well at RPM with only an occasional cough (one every minute or two). Timing at RPM looks like about 10 deg. ATDC. So the only ideas I have at this point are (1) to tweak my distributor by extending the timing adj. slot to provide a little bit more retardation, or (2) perhaps double up on the head gasket to try and reduce the compression a little. Your thoughts appreciated...
