2n hydraulics?
Patrick
09-18-2001 18:20:33
My 2n hydraulics make a knocking sound when lifting a heavy load. When it has not run long enough to warm up it pulses as it raises. The Ford dealer says it is ok, but i do not think so.Any ideas?
Ed-Illinois
09-19-2001 06:37:12
 Re: 2n hydraulics? in reply to Patrick, 09-18-2001 18:20:33
The big question is, does the 3point hitch still lift well?
My 2N's pump will make a knocking noise when th fluid is low. I understand from previous posts that the knocking noise is not that big a concern.
David(KY)
09-19-2001 04:44:19
Hey Patrick
I'm still learning about these n's myself so i can't be much help...but i know if you check the
archives at the top you will most likely find your
answer...theres alot of knowledge in there..try typing in 3 point hitch or hydraulics...sorry
couldn't help more.
good luck
