Pastor Scott- I don't know how mechanically inclined you may be, but if you have spark at all four cylinders, then the problem is most likely fuel related. First things first. Determine if fuel is getting to the carb by closing the fuel valve at the bottom of the tank. Then disconnect the fuel line at the carb. Leave the carb line disconnected and place a can or bucket under the line to catch fuel. Once the line is removed, go back and turn on the fuel valve at the bottom of the gas tank and see if fuel runs from the tank to the can. Fuel should be clear in color and run smoothly. If the fuel runs fine, then the carb is the culprit and you'll need to clean and/or rebuild the carb with a carb kit ($20). Fairly easy to do and will take around an hour or two to complete. If fuel does not run, then the problem most likely is in the fuel shut-off/sediment bowl unit. This unit can be removed from the bottom of the gas tank, but be ready to catch any gas that is in the tank. Once off, you will have to different screens that act as fuel filters that can clog up. There is one inside the tank that attachs to the assembly. The other one can be found above the sediment bowl. Make sure these are clean. Hope this helps and good luck. Don't be afraid to ask questions at this forum. Everyone is here to help and wants all ford users to enjoy their tractor to the fullest.
