Loose sleeve
Roger
09-22-2001 20:55:42
When I took the head off and pushed the #3 rod and piston assembly out the top, the sleeve came with it! 1 Question:
1. How can I anchor the sleeve so it doesn't move?
I thought I read something about JB Weld a while back on this forum, or is locktite a better product
Thanks for any and all help.
crason@udata.com
09-23-2001 06:24:02
 Re: loose sleeve in reply to Roger, 09-22-2001 20:55:42
Roger, I would think long befor I glued a sleeve in. At some point, maybe now, you will have to take it out and replace it. If you glue it in it may not come out unless you bore it. If the sleeve are worn check into getting a sleeve kit. I think they sell oversize sleeves for your problem. IF you want to keep the sleeve, try SERVICABLE loc-tite. You could heat the sleeve and pull it then.
smokie
09-22-2001 21:37:02
are they thin or thick wall sleaves if thhey are thin wall ya mite want to put in the thick wall 0.90 this requires reboring tthe block loose sleave are not a good thing.
goodluck
